Hello,
This is my first post, hopefully you all could help. I ran my boat this past weekend and started having problems as soon as I left the port. It started up no problem at the ramp and in the harbor idling. As I got on plane and left the port it started to depower and lower its RPMs and eventually shut off. It wouldn't turn back on after that. There wasn't any buzzers going off and it was peeing pretty strong and wasn't over heated. Once I took it home and charged the battery I tried to start it up again. I checked the inline filter and the fuel/water separator and they seemed ok. Once I primed it up again and tried to start it, it idled shaky. I could rev it up in neutral but as I came down it would shut off. After that it wouldn't turn over again. Any ideas? I hadn't run it in over a month but last time I did it ran perfect.
