This is a clarification of a post I recently made about my Kohler lawn mower engine. I posted that there was fuel gushing out of the air filter box. People replied and said that it could be the needle valve or a problem with the fuel pump if it is electric. Here is the update.
When I removed the muffler it had a quart of gas in it. I took off the carb and tested the float valve by blowing into the inlet. When the float was in the up position it stopped the air flow. I also found out that I have a pulse type fuel pump and an electronic fuel shut off valve on the float bowl. I tested the electronic valve with a 12 volt battery and it clicks and pushes upward so I think it works.
I ask about the dealer about buying a carb rebuild kit and he said it cost over 100 dollars and they do not sell individual parts to the carb. I think we have a communication problem here. He suggested that I just clean out the carb. How should clean this particular carb?
Thanks for the help
Thanks for the help
