Rinker 192 lists to left
drinker 192
I have a 03 192 with a 4.3 mpi and it lists to the left unitl you plane it out. Once it is on top of the water it is fine. I know it is a little heavy on the left hand side because I installed an extra battery and amps for the radio, but it did this before the install. Should I try trim tabs or just move weight around in the boat? Any input would be appericated.
Thanks,
