Overkill82k5
- Jul 29, 2009
- 78
Had an issue pop up while out on a long weekend trip. I know this is bad, but was wanting to get some feedback on rebuilding vs. repower, parts availability etc.
The wife and I decided to take a long weekend and do some wandering since the weather here in Fl has been so hot lately. We put in at Titusville and wandered south on the ICW until we got to Ft. Pierce. The chop was pretty heavy on the ICW so we decided to kick inland to Lk. Okeechobee and maybe make our way up the Kissimmee river to see how close to home we could get by boat. On the first day we made it to the big lake and spent the night there. The next morning we started towards the north end of the lake to get to the Kissimmee river. We were cruising along the canal on the SW side of the lake after refueling and the motor started to stumble a little bit. I had been having issues with the carbs since I got the motor and finally pulled all new fuel lines and cleaned everything out really well. I assumed the stumble was fuel related, as in more of the old fuel line remnants breaking loose from somewhere and giving the carbs a fit. I opted to open it up for a minute and see if it would clear itself. It did for a few seconds then all hell broke loose and she quit... hard.... We got a tow back to the nearest boat ramp and I called a buddy to grab my trailer and come get us.
The day after we got home I pulled the plugs to get a visual on the pistons. The lower port side piston looked bad. I pulled the head and found the issue... LOL.
Motor is a '96 Johnson 112 SPL and I am contemplating pulling it down and rebuilding, buying a rebuilt power head to swap or finding another outboard (used) to just swap it out with if I can find one cheap enough on CL or a classified somewhere. The boat is an 18' Wellcraft bowrider that I restored the transom, stringers and sole on (actually still an ongoing project). The ID plate says 150hp is the max for the hull and for kicks I would like to find something closer to the 150 than the 112, but price will ultimately dictate what happens on that end... So... What would you do?
Here's the pics of the bad cylinder/piston and head. I'm guessing a rod or wrist pin bearing died and made it's way into the cylinder...
