travelinlight
- May 21, 2010
- 11
I have an 88 Johnson 90HP, it normally runs about 35-40MPH. This morning I had it on the water and it ran fine I fished for awhile and when I started to head back in it would only run about 10MPH. I had it WOT, but the motor doesn't sound like it is wide open. I don't have a tach so I don't know the RPM, does this sound like a throttle adjustment problem or something different. This is on a side note: if the motor is in gear will the prop turn?
