Juggo
- Mar 31, 2006
- 7
I have a 13'6' 1980 Boston Whaler Sport. I've kept her in my garage for years but now I need to set a mooring on a lake in about 8-9 feet of water. It's a muddy bottom. It's not sheltered but the lake isn't very wide (about half a mile). It is long, however and it can get snotty if the wind is coming in the right direction.
I have a 100# long shank mushroom. The guy at the marine store said rule of thumb in the ocean is about 10# per foot, so 150# would be the recommendation, but in a lake, 100# should work. Is this accurate?
I have about 14' of 1/2" chain. I thought the water was more like 7' when I got the chain, then rechecked it the other day and it was reading between 8-9 feet. Will that be enough or should I attach another couple feet of smaller chain? The guy at the store said they usually go from 1/2' chain shackled to a lighter chain in deeper waters. He said in shallow waters, one piece of 1/2' chain should be fine. I have about 10' of painter line as well. Could I use that to extend out my angle?
Finally, are there any rules of thumb as far as where to drop it? How close to other boats can I get? It's a little tight. Is there a way to "set" the mushroom? i.e. hold the ball and run circles around the mushroom. Anything else I should consider?
Thank you in advance for looking at my questions.
