Well I'm back working on my engine again. Seems I take a few months off, enjoy the other boat, then come back to this one.
Here's my problem. I cannot get the engine to idle down to the right rpms in water, without it wanting to die out. I get it down to where it needs to be and it gets really bumpy and sometimes just stops. So I'm stuck setting it a little higher in gear, maybe 900-1000rpms, but when I shift into neutral, the rpms go up to 1400-1800. If I clunk it back into gear it drops down to 800+ or so. I have done a link and sync and the throttle plates are closing 100% when in neutral.
I've done the most obvious things here including rebuiling carbs (reset float 3 times), check for air leaks, new fuel lines and tank, cleaned recirc valves, new veranatherms, new waterpump, I re-sealed the gearcase borrowing mechanic's tools, set idle and WOT timing, and more I probably can't think of right now. The engine runs perfect off idle, through the rpms to WOT with no hesitation and all out power. I just can't get it right. I've included a video since a picture is worth a 1000 words. Please advise me what to do next.
http://www.youtube.com/watch?v=tiX0X3tdRsA
couldn't get embed to work, so direct URL above.
