Re: alpha one not shifting??
a little info on your boat, perhaps? engine, drive, gear ratio etc...
i had the same thing happen to me with my alpha 1...and i shredded the top unit gears. lower unit will still shift, but the power will not be transferred to the lower unit at all. what did your engine temps look like? if they spiked, the impeller is not pulling any cooling water, and chances are good you may have a similar problem. pull the top cover off the upper unit and take a peek at those gears.
if they are ok, you may have a spun coupler, which sucks a lot. i am not sure how to check for that, maybe some of the more experienced people on here can help?
anyway, if it is the drive, i ended up grabbing an SE-106 from sterndrive engineering, direct replacement for the alpha 1, and it comes with a sweet 3 year warranty.
