Transom Question with Offshore Boats
cs28461
Have a 24' Carolina Skiff 2400 Offshore. With the trailer, it measures 32'. The enclosed storage I have is 32'. With the motors trimmed up and the "resting plate" switched down on the motors, I cannot get the doors closed. If I trim the motors down (about 6" off the ground), I can get it in snug.
Will this cause problems with my transom down the line (as in needing to be replaced because of weight distribution)? Should I look into a break-away tongue?
Boat storage is very pricey in my area and the place I am in is a good deal.
dingbat
Re: Transom Question with Offshore Boats
Motors should be stored in the down postion if possbile for enviromental porposes. No harm to transom either way.
Home Cookin'
also better for your motors for a lot of reasons. just remember to rtaise them before you get out of the storage unit, a small hump can get you.
