  #1
Old May 30th, 2002, 09:32 PM
markwadd markwadd is offline
Default New Boat Problem - Need Advice
Just bought a new boat and it doesn't seem to be going as fast as it should. It's a rinker 232 (23ft) with 350MAG Bravo 3 and only hits 43mph at 4400rpm. The prop is a 28 pitch. Dealer says that it should do 55-60 easily, but does not know what is wrong. Dealer recommends waiting for 10+ more hours and see if it gets better.What should I do?... Mark
  #2
Old May 31st, 2002, 03:14 AM
FlyBoyMark FlyBoyMark is offline
Ensign
Default Re: New Boat Problem - Need Advice
Mark,Your present configuration is showing that your theoretical speed would be 58 MPH with your present prop. So running at about 90% effeciency, 52 mph....I think your not trimming the outdrive up properly when under way. In additon, I THINK, you might be overproped 2" of pitch, but, that really depends on the weight of the boat. Your running about 200 RPM BELOW the recommended envelope of 4600-5000 RPM. ONCED trimmed properly you might pick up the needed RPM and speed. Even after breakin, another 200 rpm or so is not going to get you 55 MPH at your present configuration. Try trimming the boat with the out drive underway. If the bow is trimmed way down it will slow you down considerably. On another thought..are you loading the boat up with a ton of people and gear when you went out? Are they all sitting in/on the bow somwhere? This is all based on th standard lower unit ratio of 2.0:1 on your Bravo unit. Is this the correct ratio or is it the optional 1.81:1 or optional HIGH ALTITUDE 2.2:1?
  #3
Old May 31st, 2002, 06:24 AM
I have tried to trim the boat out of the water and that is when I get the better RPM (4400). The boat is approximately 4200# and the ratio is 2.2, and it doesn't get anywhere near 50mph. This is with a full tank of gas and 2 people on board. I talked to a friend that has the same boat but with a 5.7 engine and he gets 53mph (gps).Thanks for the help... puzzled... Mark
  #4
Old May 31st, 2002, 03:03 PM
Ensign
You should be doing about 45-47 MPH with the gear ratio of 2.2 and 4400 RPM that your puting out based on 90% effecientcy.Why on earth is the 2.2 high altitude ratiio in your lower unit?! Very ineffecient for higher speeds.@ 4600 RPM, after breakin, 48-50 MPH What ratio and prop pitch does your buddy have on his boat?
  #5
Old May 31st, 2002, 03:09 PM
Ensign
Just checked Mercury charts, 54 MPH is all your supposed to get out of it @ WOT unless you prop just for top speed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OMC 3.0 Overheating Problem! Need Advice. gking Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 July 9th, 2006 01:59 AM
problem with used boat purchase...need advice k5ranger Dockside Chat 8 May 26th, 2004 01:13 PM
problem with used boat purchase...need advice k5ranger Trailers and Towing 8 May 26th, 2004 01:13 PM
91 Jeep problem/advice DaleT Non-Boating Technical Topics 16 March 11th, 2004 11:02 AM
found the problem! need advice on what now? loganmallory Johnson & Evinrude Outboards 15 June 15th, 2002 01:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
