Hello all, I have a 68 9.5 sport win. Cannot get top end when running wot. Seem like it is running on 1 cyl. I have replaced points and condensors, set at .020", rechecked settings. Swapped coils from on to the other, and my bottom plug is cold to the touch after running for a couple minutes. Top plug is hot after same run time. Also have changed plugs.
Engine starts fine and runs great, just no top end.
Could this be a plug wire problem? I have checked continuity and is good.
Thanks Mike
Thanks Mike
