roamrocker
- Jul 5, 2010
- 18
Ok so here we go again. I took the boat out yesterday and after about half of the day my trim stopped working. When i opened up the tank to look inside the oil was nasty milky so i got water in there some how. After getting the boat back home i drained and flushed everything and got it working properly again. Now that the system is working again i can run the trim up and down and i do NOT leak any fluid out. I would think that if i took water in it would leak oil out when cycling the system in my garage. My next question is about the manifold on the bottom of the transom where the 4 lines connect into the sides. On the bottom of this manifold there is a small plug. After looking at the manual for my outdrive (Page 553) it is shown there but it does not give a reason or a purpose for it. Could this somehow be the cause of my leak? Is there somewhere else i should be looking? All the connections on the cylinders were tight and the manifold is the only other area with connections under water.
Thanks for any help.
