old as dirt
- Jul 13, 2010
- 2
I've read a lot of good info on this site and I'm hoping that someone will be able to help an old retired mechanic (me) tune up my Son-in-laws 140 Mercruiser S#5437622. He bought it on the trailer without running it on the water three weeks ago. I belive the previous owner was having problems as it has a new starter, new Rochester carb #17059050, new coil, new plug wires and a new Pertronix electronic ignition complete distributor. Must of cost the guy a bundle for all this stuff. The problem is hard starting and when it does start it has to be at wide open throttle and if you back off too soon it stalls then is harder to start up again. Once it was warmed up on the lake it seemed to run ok, according to my son-in-law. Here is what I've found....when the iginition key is "ON" there is no power to the +side of the coil when I try to start it with the muffs on. I've also had the ignition switch turned "OFF" and while using a remote starter button from the + battery terminal to the solenoid start wire to check that the (hydraulic) valve lifters are all working the engine tries to fire up. So, before I go under the dash to the iginition switch to check out why the switch isn't giving the coil power when "ON" I wanted to put this problem out to the experts who have a hole lot more Marine experience than this old guy. Any suggestions or advice I would surely appreciate, thank-you.
Brian
Brian
