313b0ss429
- Jul 18, 2010
- 8
Hi, i just recently bought a dynasty jet storm. when i bought the boat it had no spark seemed to be a easy fix as the ignition is very simple. but my problem is now i have tried many things even as far as buying another used ignition everything but the stator. i already have 3 16 amp red stators all 3 ohm test fine right around 650 to 680 on green white wires. yellows ohm at .4/.5 volts. i tested the a/c output of the stator on the motor and it cranks right around 180v. so this all would tell me the stators are fine and i tested the triggers as well which test fine. but my big problem would be i have no idea if i have power going to my switchbox. the boat was on the 3 days before i bought it so i know it ran recently. its getting fuel and has great compression just no spark. so how do i go about testing is i have power going to the switch box i have the red stator with green white wires which go into a small black box called the stator adapter and comes out with 1 ground and 1 purple wire but i am not sure how to test that adapter 2 see if its good or not. short of me buying a good oem black stator and hooking it up i cant test my system anymore till i find out if the adapter is good. if anyone has any idea what kinda voltage the adapter should put out it would help me out greatly thanks.
