Re: help removing drive shaft
Hey Bob,
Thanks for the reply. I believe it has carbs. I tried pulling again last night, 1/4" moving smoothly then up tight. I can see the rear o-ring through the exaust tube on the top of the unit, I should be getting looser not tighter. Is there something that needs to be removed from the shift shaft down deep that is hanging as I pull it? From the drawing it looks like it should slide away.
Dave
you have to UNSCREW the shift rod!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!(BUT NOT TO REMOVE THE BEARING HOUSING!!)
if it hasnt already turned...count the rotations, and remember them...!!!!!!!
the instructions are in my hands and basically says:::::
...remove the two screws, washers and retainers
use an appropriate PULLER to pull the bearing housing out of the lower unit
NOTE: the bearing housing should come out with out anything else being unscrewed or taken off.
after that the reverse gear comes out with the thrust washer and thrust bearing.
it says there is a small thrust washer on the face of the gear or on the prop shaft..makes sure that cvomes out as well.
after that...you have to unbolt the pinion gear, and drive shaft, to remove any more stuff out of the lower unit.
they say to push DOWN on the shift rod to engage REVERSE, then unthread the rod from the detent lever.
now you can remove the PROP shaft and the rest of the stuff on it!!!
pretty straight forward...no snap rings
if you are still stuck i can take some pictures of the manual and send them
good luck
bob
