Ayuh,... You have to isolate the blocks cooling passages by disconnecting hoses, plugging, etc, then pressurize with air, about 15psi...How can you tell if it is a cracked block?
I did. But I started it in April and then it froze again in May and June.
A freeze plug was popped off when I took it out the first time.
