reawillplay
- Jul 16, 2010
- 1
What is the procedure to resealing the upper unit. Took my boat into have upper unit resealed and now the boat is not working like before I took it in. It is overheating and will shake when you put the boat under a load for example runs fine except when you pull a tube. Did any part of the units have to be remove? and what might have been done to cause the problems. Thanks for your help.
