magicman1223
- Apr 6, 2010
- 52
Alright I seem to have an issue with power going to my head unit. Im running a sony gl17w with boss marine speakers all around. The issue i'm having is the head unit will shut off if the volume gets turned up any were above half. The reason I think its a power issue is because I tested it with my multi meter and i'm getting 12volts before the radio is turned on. Then as soon as you turn up the radio it falls to about 5v. Has anyone else had a problem like this? I noticed if i ran an additional lead from the battery to the head unit i was able to turn up the volume as loud as i wanted without the head unit cutting out. There is still a lot of voltage drop in the line i'm not sure what would be considered normal. but seems to drop to about 8 with the volume all the way up with the additional lead. Any help would be appreciated. The boat is a 2001 q3 with a 125 outboard. Thanks
