starter replacement on 1998 monteray explorer
zbnutcase
Re: starter replacement on 1998 monteray explorer
Hard to say without looking, but not uncommon at all to have to remove an exhaust manifold or even remove the whole engine, starters can be a real P.I.T.A.
Ayuh,... Either remove enough of the boat to reach it, or pull the motor...
Creck
I have a 97 and just changed out the starter. It's a little tight, but with a little work you can get to it without taking the exhaust off.
Good Luck
Creck
You may want to consider shims. I had to use .0400 shims to get it to stop binding. Good luck and happy knuckles.:)
