OK, I have a 1989 Johnson 70 that will not idle in gear for longer than about 30 seconds. It will idle forever in neutral. I have already changed the idle mixture as detailed here: http://forums.iboats.com/showthread.php?t=361234. The mixture change improved things, but it still won't idle for long. I have also done a full rebuild and link'n'sync is right on per the manual, with the exception that the idle speed is a little high.
To reiterate my question from the other thread, is it possible that having the idle speed set too HIGH is causing the stalling? I set the motor to about 1200 on the muffs, which worked out to around 850 RPM on the water, against the spec of 700.
I would have thought that having too low an idle speed would make it stall, but maybe too high is worse? Unfortunately it's not really easy to experiment - I need a quiet lake and there aren't any around here.
Thanks for any assistance.
Tim
Tim
