were can i get a 14ft transom mount steer cable
skruff33
hi was wondering if anyone had a clue on were to get a 14ft transom mount steer cable i checked i boat store ,ebay no luck,i no this is a hard to find part i think.it as a nut that attaches the cable to the seer wheel then the cable extends 14ft to a round cylinder that attaches to the transom then to the motor,any help or sites would b great,thanx
F_R
Re: were can i get a 14ft transom mount steer cable
The cable is the same, be it transom mount or tilt tube mount. Obviously, the length will be different, according to the boat.
Now, if the problem is the motor attachment at the end, and your old one was a spherical ball joint, you will have to buy a new rod end because the new cables are not threaded. The new kind is a double jointed affair that does the same thing as the old ball joint.
