green_head_getter
- Jul 15, 2010
- 41
Hey guys I am new to the forum and I need help. I recently acquired a 15hp Johnson 78 model. Model # 15R78B
This motors lower unit was rebuilt 2 years ago and is in great condition. I had to fix the pull start, install a new impeller and then I tried to get it to run. the motor would run but it had to be given alot of gas while pull starting to get it to fire up. Then after I got the motor running it wouldn't idle low. I would try to run it at start speed or shift speed and it would die. I figured the low idle jet needed to be cleaned. A carb kit was in store. I took apart the carburator and cleaned out all of the nooks and crannies with carb cleaner and an air hose. (got instructions from another thread) I made sure everything was nice and shiny and then I installed the new kit. Put everything back together and it fired up the 2nd pull. Idled alot lower than before but still wasn't perfect and would die if you turned it down to low. I played around with the low speed jet tightening it in and then back out 1 1/2 turns like factory recomends. Now the dang thing won't hardly start. I can't sometimes get it to fire while giving it some gas and then as soon as it starts running it acts like it floods out. What is doing this?
