Will storage and some fuel evaporation lead to a greater oil to fuel mixture?
Parameters:
Bayliner 1984 Capri, Force 125 (2 stroke), inside/integrated fuel tank (28 gallons?). I add 6 gallons of fuel at a time as this is a one bottle (16 oz) of two-stroke oil per 6 gallons of fuel. My engine exhaust smokes pretty good, although the engine runs very well.
I use this boat only in the spring and fall when it freezes at night (before I put my Regal sterndrive in the water and after I retire it for the season). I stabilize the fuel each time I add fuel/oil.
I leave the fuel tank cap closed, however there is a vent tube through the transom.
There is no fuel smell or obvious leaks when I have it stored in my storage building.
If there is some fuel evaporation, will the oil mixed with the gas evap at the same rate or will the mixture become more oil rich over time?
Parameters:
