1985 Bayliner engine identification
SnarlingSnoyl
I have researched how to identify this engine for several days now. I wasn't able to find a tag on the motor anywhere so I now post this information for the experts to decipher. Also, it may be possible that the current motor is a replacement for the original.
ENGINE:::
Volvo Penta
GM V8 (i'm not sure, but GM is cast into almost every part)
Large marking on the end of the block above oil filter : 3951511
Intake Manifold marking: 346250
Firing Order: 18436572 (also a GM firing order)
DRIVE:::
Volvo Penta
PN: 850678 8419
Serial: 656871
Hopefully, somebody can shed some light on this mystery. If you think picutes will help, let me know what you want a picture of and I'll post it on here.
Thanks,
Michael
Re: 1985 Bayliner engine identification
Ayuh,... Pictures Never hurt a thing,... Just post 'em 480x640....
At this point I can tell you it's a SBC,... Either a 305 or a 350 Chevy...
Welcome Aboard Mike,...:)
SnarlingSnoyl
Haha. Now that I take a second look, it looks like someone dropped an 350 SBC in it. It has a modern HEI distributor and a modern Edelbrock 4 barrel carb. Is this a common thing to do with old Penta drives?
Also, if whoever put the SBC in didn't use the marine heads and cams, could this be trouble? I am assuming that these are important for a marine engine. If so, how available are these parts?
Thanks for your help,
Michael
Ayuh,... I just checked the block casting #s,... 3951511
It's a 70 to 80 400cid SBC....
Same motor I bought a couple weeks ago for a Wellcraft Nova project I'm workin' on...
I wouldn't worry about the Heads,...
The HEI distributer is another story though...
Electrical parts MUST be Marine rated,...
'n that Ain't...
SnarlingSnoyl
Alright. This is good to know. Any suggestions on the a distributor because the case on this one is cracked and the vacuum advance is completely corroded.
Also, does anyone know what model outdrive this is? I was unable to decipher the part number using Volvo's guide.
zbnutcase
You can get a Mallory marine distributor from Summit Racing, among other places
