What year/info is this motor...need help
DamianJP
Hey guys
I just got a engine for my nephew. Guy told us it was a 2000 6hp yamaha but I think it's a 5hp either a nissan/tohatsu or a yamaha. When I look up either a yamaha or nissan/tohatsu they seem like only 5hp and under had the internal tanks. As you will see the pic, it had a internal tank cut out at the top of the cowling and a mount above the power head.
Only info I have on engine is the stamped circle number off the powerhead since it's be repainted.
Serial ? 08568
Says use BRP7HS10 if its a nissan/tohatsu 5HP (it had a BR7HS10, what is the diffrence between BRP and BR)
And if its a yamaha says to use B7HS
Im going to need the following info when we find out what it really is...(I prolly can look it up but if you know feel free to chime in)
1)Spark plugs it should take
2)Oil Ratio
3)Lower Gear Oil
Heres the pics
Thanks guys in advanced,
DamianJP
GoogieMan
Re: What year/info is this motor...need help
B: - 14 mm thread
R: - Resistor
P: - Projected Insulator Type
Sorry have'nt the answer to the rest of your thread
rodbolt
me either other than it looks like something from the 70's.
DamianJP
Hey
Thanks GoogieMan and rodbolt. Found out it is a Nissan 5hp and other info too.
Sorry I know this is a old thread now but I wanted to say "Thank You" to you guys. Spark plug info is cool too :)
Thanks again,
DamianJP
