antique fisherman
- Feb 10, 2010
- 85
I recently acquired a 85hp 87 Rude which hasn't been run in quite a while. It wouldn't start or run and I found out that it wasn't getting fuel. I rebuilt the fuel pump, removed and cleaned the carbs with compressed air, still no firing.It has two carbs with two throats each. As long as you inject fuel through the throats, it will start and run until it burns what you injected . It then won't restart until you inject more fuel you. Do you think that it still has carb problems or am I missing something ? Any help is greatly appreciated . What are the chances of both carbs being bad at the same time ?
