summary : bought this motor last weekend - new to boating so i thru it on my boat & iwas off . not relizing it was a long shaft i put it on my boat - 15 minutes later it would coninue to run ... i would have to pump fuel and it even began kicking the fuel line off ... i think i had the outlet for the water pump in the water ;( now i cant get motor to run for long periods of time as it seems to lose vacuum and run itself out of gas.. i cleaned carb & replaced fuel pump ..side note water leaks now from shifting handle .. it will not run with choke on ..when it does start it runs short burst once stalls i notice no fuel in system at all .. i must repump gas tank & i here it filling an empty carb all hoses empty of fuel as well ..
help me . is this an issue of a gasket near the water pump causing pressure to be lost ,....
