Re: popping out of gear
i to have an evinrude 30hp big twin that is pooping out,,,it sounds like a misfire but i checked it with 2 spark testers beside each other cause i thought it was a condenser problem but neither side stopped flashing and i noticed it was coming outta gear,kinda like skipping a tooth though not much,,so i figure it may be the clutch dog or forward gear,,,,so i go to drain the lu grease and it is all water again,which i just had all new seals put in it by a boat man,,,,would the water make it jump out cause if i hold it in gear then it stays in but if i give it alittle more gas then i cant hold it in and it jumps just like when idle,,,so no matter if i'm wide open or at idle then it will keep jumpin out at every 3-5 seconds what can i do bout it,,boat mans on vacation,,if the gears were bad then he would have noticed and same for the lower unit
