shane01101
- Jul 12, 2010
- 17
I have a 19.5 ft 1990 bayliner capri and the steering on my boat is a little stiff. Turning to right is stiff but turning to left is not so hard. I am hoping I can fix steering by cleaning the steering cable. I have never done this and wanted some feedback on what to do. Is this easy to do and anyway I can damage cable? Or any real helpful tips? I got all my info from video I am attaching...
So what I have researched on how to clean steering cable is..
1) I unscrew the cable on both sides of tilt tube
2) Clean inside house of steering cable
3) Use White Lithium grease and give new coat to inside and outside
4) Use a new Drag link Lock nut to re attach and make tight sealed connection
Questions??.....
Is White-Lithium Grease a good choice and how much should I buy? How do I find correct size Drag Link Lock nut? What do I use to clean inside housing of steering cable that atatched to engine? Do I clean actual steering cable or just grease it? Im going to buy stuff I need off ebay or maybe even marine store if not costly but it usually is alot higher than ebay on prices.
I found only 1 video off youtube on the process but it does not show you how it is just basically a quick summary but good info.
Vid http://www.youtube.com/watch?v=IucARiVT0JE
Questions??.....
