Re: What Pitch do I need?
To answer your question the RPM at 57 mph is around 6400. The problem is that I took it out this past weekend and pulled my daughter on a tube. I normally used it for fishing, but I was doing the family thing on this day. So I ran maybe a little over a quarter of a tank of gas out and stopped to swim. About 30 min we got back in and rode down the lake not pulling anyone just riding and let them off at the ramp. I was waiting for them to back the trailor in and an alarm went off. BEEEEEEEEEP!! The beep was solid and didn't stop. The first thing I thought was over heating, because the oil injection has been disconnected.(I Premix) I shut it down right then cause I was skeered. I started it back up and pulled it on the trailor and it started beeeeeeeep again. I have read a lot of different things on here about that issue and will try some of that stuff, but I was thinking if I had to small of prop that the high rpms would cause it to overheat when trying to pull someone. Thank you so much for your help.
