Re: Price of rebuilding a lower unit?
Bearings feel bad, gear lube pours out faster than i can put it in from behind the prop shaft. also, when I had it off the motor, I couldn't hardlt turn the main input shaft in forward, neutral or reverse gear with a pipe wrench.
