I have a pair of 1992 Yamaha Wave runners. One is a 650 Waverunner III and the other is a VXR650. I took out the ski last weekend and both were running great. After about an hour the VXR650 started to have an intermitant hesitation. After about 20 mins it got worse till the ski stalled. I added fuel primers to both skis to help with starting. I tried to start it and it would not start. I pumped the primer and it fired right up. But only ran for a few seconds. The more fuel I fed the carb the longer it would run. I towed it back and started checking. I know more about cars then skis. I figured it was the fuel pump in the carb. (the previous owner told me to have that carb rebuilt eventually). I rebuilt it and it is the exact same way. I checked the fuel selector. It workes fine. I can blow fuel through the system from each fuel line (regular and reserve). Fuel line with the fuel filter I can blow fuel through too. But I can't get the carb to pump any fuel. At this point im lost. Any help would be appreciated.
