Problem staying running
mrrat
Johnson 1967 55 hp needs to be cranked a few times even when warm but fires up and idles fine for about a minute then instantly quits. gas line from primer bulb to motor is fine. when you squeeze the primer bulb you can hear the gas go in. Can't figure out why it quits so abruptly. Any suggestions would be appreciated. Thanks.
