Hey guys I?m trying to trouble shoot this problem.
What I know is the impeller is new, cup and stainless plate are smooth no grooves or obvious wear, water pump housing(put new pick up tube rubber seal in) does not look worn or any obvious damage, gaskets are good, thermostat works, new thermo switch. It?s been ran in fresh water only.
Is there anything else I can check?
I?ve found a couple different spec?s on the idle setting. The first spec is 800 +/- 50. The next one I found was 750-850 for the idle in neutral. It had a note under the trolling rpm column. It said those numbers are for all models except ones with PTT they should be 1000-1100 idle in neutral and 750-850 for trolling. Mine has PTT.
Which is right? 1000-1100 seems a little high to shift gears, to me anyway.
Before I purchased the boat the previous owner had it into 2 different shops for this problem(and others) and they both thought they figured it out.
In neutral it won?t over heat but in gear it will happen pretty quick. It goes into protection mode.
Also the motor/boat does not have a horn or warning light. I would like to wire in a light for the temperature and I can?t quite sort it out thru the wiring diagrams I have.
Can anyone tell me which wires to use?
Cheers
Mike
Cheers
Mike
