Re: 35 HP Evinrude Prop.
I don't believe I will be able to get you the RPM as I don't have a tachometer, however, I will take the boat out and get a GPS speed.
The boat is between 450 and 500 lbs. I unfortunately do not have the facilities to weigh it, and this is the best I can find with a google search.
The gas can is a metal pressurized unit, 6 gallon capacity.
3 life jackets, two danforth anchors weighing 10 and 12 pounds respectively, each with 100 ft of 3/8" poly rope.
One six pack size cooler full, tackle box, two fishing rods, one five gallon bucket, a blanket, two coats, two quarts of oil, spare prop, and tools.
Two people, one being 140 lbs the other varies, either it is my wife who weighs 100, or someone else probably closer to 200.
Anyway, I'm really just listing this so I remember to weigh everything.
The boat is a 14 ft fiberglass made by Fabuglas. Year is supposed to be 72'
The hull is a V hull with the hydrofoils. Closed Bow.
Typical activities, fishing. That's pretty much what I do with it.
