I've got just one last seal to get out and replace. Will this bearing head seal pry out or will I have to dremel it out like I did for the drive shaft seal?? Any body know the best way to remove this seal?
Dremel it. Prying it out will probably break the thin wall around the seal. I put the bearing head in the lathe and cut the seal out. Easy for me to say, since I have a lathe.
