Re: manual fuel pumping no oil warning
My 50 evinrude sucks. It wont stay running unless i manually pump it and then it only runs for about 5 min before the no oil warning buzzer comes on. how can i not be getting fuel or oil? My manual ball pump on my oil tank is hard as rock and cannot be pumped. I can shut it off and restart it as i wish for 5 min periods.
Hopefully others will chime in, especially if I'm way off base on this.
But I think having to manually pump the bulb is a classic sign of fuel pump failure. In your engine, if it's a VRO (aka OMS) pump, the same air motor drives the fuel portion of the pump and the oil portion. Therefore, if it's failing, it won't drive the fuel portion of the pump (thus you having to pump the bulb to keep the engine running) and won't drive the oil portion of pump either. The "no oil" alarm is triggered by a sensor that monitors the oil pump portion - if it's not working, or not working well enough, it will drigger the "no oil" alarm.
At least this is what comes to my mind, hope it makes sense.
Read this article, which shows how the pump works.
http://continuouswave.com/whaler/reference/VRO.html
In case it matters to you, if you decide that it is in fact a bad VRO/OMS pump, it's a pretty easy do it yourself to replace it. The pump is kind of expensive, but if you have a service manual, it's a 1-2 hour easy job with basic, simple tools. I did it and I'm no mechanic.
