Re: How to pick up a Baja 1995 20' hotshot?
Welcome. Your cobalt transom pull loops are most likely hooked to your stringers, that's why they are so close to the outdrive, not so on most boats. they are just a u-bolt with a small back plate and were never intended to support the weight of the boat.
your lucky you did not drop the boat. use the straps.
sorry about the damage but lesson learned.
hope you enjoy the Baja.
