Re: mercruiser 120 hp does not reach full throttle
How about all the rest of the info?
Is the engine overheating, have you checked for proper timing advance? Is it rubber or blow by gas you smell? Is there somthing wrapped around the prop, is the carb too lean, etc........
Lots of stuff to check thru process of elimination.
