This is my third boat all others have been i.o.'s.
I've changed the powerhead on this 50hp Force (507Y8D) because of a melt down. After tearing it apart, it's back running again, but it still has the same cooling issue. There's only exhaust out the pee tube.
I was told the impeller is new, & after inspecting it it doesn't look worn. The water pump housing looks grooved a little, but should still work. The copper pickup pipe went back together fine & sits in the bottom of the powerhead correctly.
1st test I removed the lower unit with engine off, I flushed water throught the copper tube, and that flows perfectly. 2nd test lower unit in a barrel of water & spun the shaft by hand to get some water to flow out the water pump spout. When all together it works with the muffs, yet in the barrell nothing.
- I have the manual & read many other threads. Sorry about the length of my woes.
