115 johnson
jdwilson73
I have a 2000 four winns i just bought with a 115 johnson outboard i am new to operating an outboard when i am pulling a skier it seems if i give it to much throttle it seems to slip like a transmission slipping in a vehicle, unless i am not tilting right, also it has a fairly new prop on it any pointers would be great
itsaboattime
Re: 115 johnson
Do you hear a thud and does the boat Jerk? If so then your gearbox, the lower unit, may be slipping. The skier may be putting too heavy of a load on a gearbox that may be already wore. Having said that, a ten year old gearbox should not slip, under normal conditions, pulling a skier.
ezeke
Re: 115 johnson
Even though the prop may be relatively new, you should still test it to see if it has spun.
Click the thumbnail, mark the propeller as shown, then take a quick run to see if it slips.
