Re: Single Axle to Tantum Axle
I see tandem axle trailers all the time with a single set of 10" brakes on one axle, you have to wonder about the wisdom have having in effect a vehicle behind you that can weight up to 7000 lbs (2 3500 lb axles) with a pair of 10" brakes. Now the tow vehicle does contribute some to the stopping of the trailer but there is no way it can or should make up half of the GVWR in terms of stopping capacity. In fact if you go back to the issue of single vs tandem, you'd have better brake performance with a single that had a 5200 lb axle with a pair of 12" brakes versus a tandem with a pair of 10" brakes on one 3500 lb axle...
On way to look at it is to figure your tow vehicle's GVWR, that's what the manufacturer thinks the brakes are capable of reliably stopping. In many cases, this is only 1000-1500 lbs greater than the vehicles curb weight, so that doesn't allow much for making up for an under-braked trailer.
When I upgrade my single its getting a 5200 axle with a pair of 12" Kodiak discs, that's well in excess of what the boat and trailer weighs....
