My 1988 3.0L four cylinder I/O Mercruiser won't crank when the motor gets hot. Runs great all the time, never gets truly hot, but when tubing towards the end of the day it won't crank unless I bang on the starter. I have tested everything in my driveway cold and everything tests out properly.
Thus I am looking to replace the starter.
Local rebuild is $110,
new online $182,
ebay by DB Electrical aftermarket new $55 !!
Thinking of going with ebay but the disclaimer says:
""NEW Mercruiser 3.0 Marine Starter Long-Short Mount 6563
Brand New Aftermarket STARTER FOR MERCRUISER, OMC,
and OTHERS from DB Electrical
Starter - Aftermarket replacement for Delco PG260M Series
1.7 kW, 12 Volt, CW, 11-Tooth Pinion
Comes with mounting bolts -'One long-one short' bolt pattern.
This marine boat starter fits nearly all Mercruiser, Cobra, Yamaha,
and Volva Penta GM 3.0 liter engines.
**This starter will not replace the older large style 10MT Delco starters
with the 'one long-one short' bolt pattern!
Search for our SDR0272 starter to replace the large style 10MT
Delco starters!** ""
Anybody know if this starter will work for me? Anybody use this starter successfully?
new online $182,
