17.5 Thompson Tri Hull
I really can't move my steering wheel in either direction. I believe my steering is a rotary system. It is only one cable from the steering arm (that bolts to the outboard) to a rectangular device that is under the steering wheel(helm). I actually disconnected the steering arm and the outboard moves back and forth freely. I also can move the arm (rod) in and out about a quarter inch while still mounted to a outer tube that holds it in place. My question is do these rotary systems sell seperate parts to add to an assembly or do you have to buy the whole system? Is there a way to figure out what part of the system is bad exactly?
