Need help identifying part
kooter
I am working on fixing up a boat I got cheap. Motor is about a 1976 140hp 4 cylinder. Sterndrive is the electric shift OMC.
Trying to figure out what this part is called and where I can find one if anyone has a good vendor to deal with. The part I am looking for is in the lower left of the first picture. I've found the other parts new online, but not this part. Hard to find it when I don't know what it is called yet :)
Thanks in advance
wnaplay
Re: Need help identifying part
I would search for an omc riser or elbow. Chances are the is probably a replacement part that may not look anything like the old one.
zbnutcase
Cheap boats are rarely a bargain!!!!
Howard Sterndrive
0908519 ELBOW,Exhaust housing
found it at shop.evinrude.com
#71 IN THIS PIC:
http://shop2.evinrude.com/AssemblyD...5&displayCatalog=179&assem=54429&catalog_id=5
or could be from a 140 - #86 in this pic
http://shop2.evinrude.com/AssemblyD...5&displayCatalog=179&assem=54430&catalog_id=5
but that square shaped riser you have laying there is from a newer unit - late 80's/ early 90's
not sure how it will line up when everything is together
that all looks like junk btw. manifold looks cracked at the bottom
kooter
#71 IN THIS PIC:
It is all garbage, as soon as I find replacement parts. Supposedly it all is off of this boat. The engine was out of it when I bought it. I've already rebuilt the engine, now working on the exhaust system before I can get it out on the water.
The riser was attached to the elbow via a hose approximately 4 inches in diameter. Hose was about 6 inches long. What normally goes between the riser and the outdrive unit?
Those links just go to a page that says to pick a year, doesn't go to the drawings. Thanks for the help
Howard Sterndrive
THE TWO DWGS- first is 1976 120HP, 2nd is 1976 140 HP:
#71 0908519 ELBOW,Exhaust housing
convert
#86 0908520 ELBOW,Adapter housing
convert
kooter
Thanks for the help. I was able to find a used replacement in decent shape, once I knew what it was called :D
