Sorry if I am doing this wrong, I am very new to this site and boats in general. I own a 16' aluminum Lund boat from the mid 80's. I believe that stringers are the supports that go from the front of the boat to the back of the boat. I have metal stringers and they are fine. The deck has rotted and I have torn it out. There was no fiberglass on the old wood where the pieces met each other or where the pieces met the side of the boat. I kept what I could for a template and did so with the carpet too. I would like to know if there are any kinds of alternatives to plywood because I don't want to do this again. If not then what kind of wood do I need? From what I understand, marine plywood is recommended but expensive. How do I prepare it (i.e. fiberglass, epoxy etc...). I have been reading information and have found that it is best to fiberglass or epoxy the wood but can't get a consistent answer to which one is best. Are there different kinds of fiberglass or epoxy to use since it is a marine application? Also, is carpet not recommended? I have seen that I can get vinyl but am not sure what is best. Again I am looking for durability and a long life. Money is not the first concern as I realize this will probably be pretty expensive. I am generally handy and am willing to try most things but I want to learn first. Any information would be appreciated and I can include pictures if anyone wants to help. Thanks again for any help and I apologize if I posted this in the wrong area.
