FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
1983 70hp
Does it run out of fuel, loose spark?
When it quits does it shut down quickly like you turned off the key, or slowly like you are running out of gas?
should i look at the primer and the fuel pump i'm going to rebuild fuel pump but can someone explain what happens when you prime at the begining run the boat for a bit what should the primer be doing during running time and when you stop the motor also does the primer stop the fuel from going back to tank my problem is when boat runs for a bit it stalls like running out of gas and the primer ball is mushy i'm running from a 6gal tank
