Re: what gasket do i need? please help
According to the parts diagram in the
PARTS CATALOG both drain and level screws are the same and fitted with the usual flat nylon wshers. # 11 in the gearcase diagram.
Be aware though that sometimes O rings turn up! If the screws fitted should have O rings the there will be recesses for them on the underside of the head. The screws that take the flat washers are flat under the heads.
Take care to only undo the two identical broad headed and slotted screws. The smaller screw next to the drain screw holds some of the insides in position. Undo it and it'll all fall apart inside
Sometimes the nylon washers come out with the screws and sometimes they stay in the hole. Take care to remove the old washers before fitting new ones.
