Re: 85 25hp evinrude shift shaft oil leak
yeah where the shift shaft goes into the lower unit...so do you recommend opening the gear case also where can I get the bushing and o ring...also if I were to put a bolt in the bushing and do it that way I wouldn't have to open the gear case correct I would just drill a hole tap it thread in a bolt and pull it up off the shift shaft and replace it with the new bushing and O ring...is that how you are saying it can be done...if so how thick is the bushing so I know how far to go without getting shavings in the gearcase.
