I have a 1994 120 hp Force outboard. Had the stator go out on it last fall and was not able to fix it until this spring and so the boat was not winterized like I normally do. Had 1/4 tank of fuel which I put Stabil in for the winter.
I replaced the stator and filled with fuel. Not sure if this is relavant or not but also had the controller and cables replaced this spring. I also ran the decarb process I found on this website using Seafoam.
Boat will not idle below 1000-1100 rpm without shutting off.
Any ideas what could be going wrong?
